93-2.3
- January 2, 2009
- 1990 bronco II
i got a 1990 bronco II that needs the vacuum shift modulator replaced on the a4ld how can i do this without all the hassle of removing the exhaust im low on cash and dont want to mess with exhaust if possible and need the truck up and running soon (its winter) advice would be great.... the modulator it allowing atf to be sucked into the motor so im pretty sure its bad
thank you
thank you
