- January 22, 2007
- selkirk, manitoba
- 98 supercharged 347 sport
the 98 explorer ecu is a 4 bank ecu same as the 99-04 ford ecu's, the main difference is the ecu clock speed is much slower, I hadn't peeked at the ecu pin out yet but most likely its all the same, once I get the clock speed worked out I suspect the 98 explorer ecu will be no different than the 99-04s
with one difference. can you add a knock sensor into it if its a 5L ecu?
