Been pulling a yard trailer for years using the factory 7 pin wiring harness. At some point a trailer wire became abraded resulting in a short that popped the 20a fuse in power distribution panel (#23 trailer tow). Replaced the fuse but see no voltage at the end of the trailer wiring harness (testing by plugging into a new set of wires/lights and looking for 12v via meter on the trailer side harness connector.
Next I looked for voltage in the interior fuse panel at #5 (15amp), #4 (15amp) and #10 (15amp). All fuses were good and showed 11.6 - 11.75 volts. All other electrical components are functioning properly.
So I supect all that leaves is the trailer wiring harness relay(s) located in the driver side rear tool box next to the rear window washer fluid reservior.
However, I see TWO relays. The Ford dealer tells me there is only ONE and the part numbers on my relays don't match the number the dealer tells me.
My questions are -
1) How do I test these relays to make sure they're working? Probe a connection point and touch ground with the other side of the meter?
2) I think the relays are OK as I can hear them 'click' when I apply the brake pedal. If the relays are OK, what is interrupting power to the harness?
What am I missing in the process here?
My questions are -
