Brayden carisse
- May 2, 2024
- Temiskaming shores, ON
- 2007 sport trac limited
I there, so this started with me heading out of town when I went to start my truck and didn't wanna start just crank (mind you worked nice the night b4) then I started seeing hard smoke coming from the rear passenger,
So I take the keys out and run to the back I ended up dropping the rear spare tire to fine above the member the fuel pump driver module was on fire..
So long story short I ordered a Dorman module and new pigtail I wierd everything up properly and even put the grounds in a better cleaner area and cleaned them.. even after all of that still cranks but no start.. so I look at the fuse to the fuel pump and its blow obviously because of the module catching fire but I changed 3 now and it's every time I turn the key to the on position blows the fuse so I'm really confused at this point maybe my fuel pump got fried in the equation not quite sure...
but really any help would be much appreciated I just got it back from the shop not long ago for exaust work and it was pricey I'd love to be able to not have to send it back there I don't really got the cash..
