daxb
- May 21, 2001
- Boston, MA
- 1996 Xlt 5.0
I have a stock 96 5.0
At autozone the code shown for my CEL was 402 which we all know by now is EGR flow excessive. Per a post by DirtyDog, these are all of the likely causes for that code (for a 99 explorer)
p0402: The EGR system is monitored for undesired EGR flow during idle. The EGR monitor looks at the DPF EGR signal at idle and compares it to the stored signal measured during key ON and engine OFF. The test fails when the signal at idle is greater than at key ON engine OFF by a calibrated amount.
Possible causes:
-EGR valve stuck open.
-Plugged EGR vacuum regulator solenoid vent
-Plugged EGR tube
-Slow responding DPF EGR sensor
-Damaged DPF EGR sensor
-Improper vacuum hose connection
-Plugged vacuum hoses
-EGRVR circuit shorted to ground
-Damaged EGR vacuum regulator solenoid
-Damaged PCM
I have researched code as much as I can (here mostly, but on some other forums too) and it seems that the a faulty DPFE is often the most likely culprit or maybe that the IAC is all gummed up with carbon per this thread
http://www.explorerforum.com/forums/showthread.php?t=84220&highlight=DPFE
Does that sound about right so far?
But per this thread, supposedly my 96 5.0 does not have a DPFE
http://www.explorerforum.com/forums/showthread.php?t=82053&highlight=PO402
I am not super mechanically inclined, but I looked for the old aluminum style DPFE in my truck and couldn't find it. I did find what looks to be the IAC based on the pictures in the threads above.
What this all boils down to is that I am now clueless as to what I should do. Any thoughts aside from taking it to a mechanic who will likely charge me crazy amounts to fix this? I have to get a new inspection sticker by the end of the month and doubt I'd pass with the CEL on and a code showing.
Thanks in advance,
Dax
Possible causes:
-Plugged EGR tube
-Damaged PCM
Thanks in advance,
Dax
