Argos587
- June 13, 2020
- Greenvile, TX
- 2001 XLT V6
2001 XLT 4.0, recently oil pressure gauge fluctuated wildly due to oil pick up screen blocked. When turning off engine this particular time, the gauge reversed and needle was located under the stop peg. I removed the sensor, re positioned the needle (pulled off needle and reinstalled) and now it reads full high pressure (fully on left side). I had forgotten these are calibrated. Can this be reset or should I replace the sensor?
Have searched online and little luck finding a sensor (only 1 used so far). Anyone know the Ford part number for the oil/voltage gauge set?
