B0omsauce
- May 6, 2024
- Wisconsin
- 2020 Limited Hybrid AWD
Hello,
After a long time of utilizing forum knowledge, I am looking to give back. Note, this may be my only post so I will try to be as complete as possible.
I recently purchased a used 2020 Explorer Limited Hybrid AWD and at 29k miles it developed a rattle/clunk from the rear. The noise sounded like something loose in the rear passenger body panel by the rear wheel well. Upon a very thorough inspection (I stripped the interior to the sheet metal) I determined the noise was coming from the passenger rear suspension. After some trial and error, I determined it was the shock mount. If you look up how a bad rear shock mount sounds this was identical to my symptoms. The PN for the mount is LB5Z-18A161-A. When I compared the old mount to the new it seems there was a material/supplier change as the old had a number of LB5Z-18A161-AC and the new was LB5Z-18A161-AD. I was unable to prove the mount had failed through testing and inspection both on and off the vehicle. What I’ve concluded is that the mounting plate inside the mount ended up grounding out to the body and transmitted the clunking noise. It appeared that the new mount may have used a new type of rubber to better isolate the mounting plate.
Note that you will need some tools you likely don’t already own. I purchased a pass-through socket set for the shock shaft nut and a specialty socket to hold the shock shaft itself. The double D socket I purchased was for GM cars (6.1mm x 8mm) size and I had to widen the opening a hair in order to fit. I also had to grind down the socket width to fit inside the pass-through socket.
All in all, the job is a 30 minute one at most and replacing the mount is 1/3 the cost of a new shock with mount. Good luck!
