Chris4x4Gill2
- December 4, 2002
- Decatur, AL
- 99 XL 4x4
Ok... you guys helped me on the driveshaft so I have a new question.
Running the EB D44 with the ranger steering box. Tried to use the pitman arm that came with the box and welded a bend into the steering rod from the bronco to get he angles to work. With it this way, it will turn to the right fine, but not to the left. seems like the ranger pitman arm with the angles of the steering jsut wont turn that way enough. I have a drop pitman coming and I thin kthis will fix the problem. What do ya'll think?
Anyone running a similar setup...what did you use to make the steering work?
