Sporttracdora
- February 13, 2023
- REDMOND
- 2003 explore sport trac
for the past year my drivers side cv axle stub has been STUCK inside the differential pumpkin. I mean STUCK!!! I have attempted to removed it with crow bars, prying evenly with 2 people from different spots. As well as slide hammering it although it was a pretty junk homemade set up. Should I be worried about the inside of the differential? Should I just get a new diff carrier?. Only 370ish dollars for a new one. I’ve had the entire diff assembly out once before to seal it back up from some bad leaks but did not know about the cv at the time.
