List of Useful Threads - TSB Information for the Explorer (List) | Ford Explorer Forums - Serious Explorations
List of Useful Threads TSB Information for the Explorer (List)
Status
Not open for further replies.
ExplorerDMB
Moderator/Technician
Moderator Emeritus
Mechanicsville, Virginia
2004 Acura TL
Any Technical Service Bulletins (TSBs) for the Explorer will be linked into this Thread so people will not have to search so hard for TSBs or Fix Information.
TSB List:
If you find a TSB on this site (only this site), please post a link to the thread or PM me the thread. I will then mark it on the list. Once the TSB you find is on the list - your post will be deleted (so do not get upset!).
-Drew
** - article submitted by BrooklynBay
Page updated: Saturday, Februrary 10th, 2007 at 2:49 PM
TSB 06-14-4 MERCON ATF IS BEING REPLACED BY MERCON V ATF AS A SERVICE FLUID:
http://www.explorerforum.com/forums/showpost.php?p=1808625&postcount=34
TSB 01-10-2 5R55W Cooler Line Fluid Leak:
http://www.explorerforum.com/forums/showpost.php?p=2070688&postcount=7
TSB 04-22-12 Increased effort to shift from drive to park: http://www.justanswer.com/uploads/fordguy4u/2008-05-18_152453_TSB_04-22-12.pdf
http://www.explorerforum.com/forums/showpost.php?p=2174863&postcount=12
TSB 07-12-9 INTERMITTENT CONDITION—SHIFTER REQUIRES TSB 07-12-9 MANUAL OVERRIDE TO GET VEHICLE OUT OF PARK—VEHICLES BUILT ON OR BEFORE 11/14/2006:
http://www.explorerforum.com/forums/showpost.php?p=2875594&postcount=13
Links with TSBs for the 2002: http://www.explorerforum.com/forums/showpost.php?p=2093188&postcount=10
TSB 08-24-4 Driveline bump while braking below 10 MPH (16 KM/H):
http://www.explorerforum.com/forums/showpost.php?p=2101625&postcount=114
TSB 05-17-8 CHIRP NOISE FROM FEAD (Front End Accessory Drive) BELT WHEN THE A/C COMPRESSOR IS ENGAGING:
http://www.explorerforum.com/forums/showpost.php?p=2109161&postcount=10
TSB 04-15-04 Timing chain rattle supersedes TSB 02-08-01:
http://www.explorerforum.com/forums/showpost.php?p=2114371&postcount=6
TSB 05-21-8 DELAYED OR HARSH REVERSE ENGAGEMENTS—5R55S TRANSMISSION—VEHICLES BUILT PRIOR TO 09/23/2004 (supersedes TSB 05-15-4): http://www.justanswer.com/uploads/timnoll/2008-12-01_220314_tsb05-21-08.pdf
TSB 04-24-17 5R55W TRANSMISSION - NO 3RD GEAR OR SLIPPING 2-3 SHIFT - DTCS P0733 AND P0745 - VEHICLES BUILT PRIOR TO 3/4/2002 (supersedes TSB 03-25-4):
http://www.explorerforum.com/forums/showpost.php?p=1416845&postcount=4
TSB 09-9-7 COLD START WHISTLE NOISE (This article supersedes TSB 8-4-2 to remove the production build date.):
http://www.explorerforum.com/forums/showpost.php?p=2192028&postcount=1
TSB 98-14-8 Antilock false activation and/or ABS lamp on with diagnostic trouble codes (DTCS) 1145, 1155, 1230, 1233, 1234, and/or 1237 stored in memory:
http://www.blee1099.com/tsb_98-14-8.pdf
TSB 97-15-28 07/21/97 TRANSMISSION - 5R55E - OVERDRIVE DRUM SPEED SENSOR DELETED - SERVICE TIP.
TSB 04B17 tire presure monitoring, and regulation system:
http://www.explorerforum.com/forums/showpost.php?p=2242974&postcount=1
TSB 09-12-12 5R55S/5R55N/5R55W TRANSMISSIONS - SHIFT CONCERNS, LOSS OF 2ND, 3RD AND 5TH GEAR, INCORRECT RATIO DTC'S - PROCEDURE TO INSPECT AND REPAIR SERVO PIN BORE WEAR.
http://www.explorerforum.com/forums/showpost.php?p=2255139&postcount=9
TSB 92-5-12 A4LD - Addition of a spring in the converter channel. Transmission build code dates 8/21/91 & later:
http://www.explorerforum.com/photopost/data/503/Case_spring_in_the_A4LD_.jpg
TSB 03-5-7 5R55W - Fluid leak from the converter housing area: http://www.explorerforum.com/forums/showpost.php?p=2396431&postcount=5
TSB 07-17-4: PARKING BRAKE RELEASE HANDLE BREAKS - VEHICLES BUILT BEFORE 12/1/2006:
http://www.explorerforum.com/forums/showpost.php?p=2409989&postcount=18
TSB 98-5A-13 BRAKES - DISC BRAKE CALIPER SLIDE GREASE:
http://www.explorerforum.com/forums/showpost.php?p=2469125&postcount=2
TSB 00-20-1
HESITATION ON ACCELERATION OR TURNING - LACK OF FUEL PRESSURE - EXPLORER/MOUNTAINEER VEHICLES BUILT THROUGH 8/15/2000 AND EXPEDITION/NAVIGATOR
VEHICLES BUILT THROUGH 6/30/2000: http://www.explorerforum.com/forums/showpost.php?p=2551438&postcount=42
2006-2008 Explorer & Mountaineer TSB list.
TSB 06-6-9 ANTI-LOCK BRAKE SYSTEM / TRACTION CONTROL / ROLL STABILITY CONTROL INDICATOR (ABS / TC / RSC) WARNING LAMP ON WITH DTC C1440: http://www.explorerforum.com/forums/showpost.php?p=2570724&postcount=18
TSB 06-21-19 Heater core leakage & electrolysis: http://72.35.72.219/~library/26079/Tech stuff/TSB 06-21-19 Heater Core Electrolysis.pdf
TSB 07-10-12 VARIOUS DRIVEABILITY AND A/C PERFORMANCE QUALITY SYMPTOMS - 4.6L 3V 6R60 EQUIPPED VEHICLES ONLY: http://explorerforum.com/forums/showpost.php?p=2573185&postcount=36
TSB 00-9-1 LEAK - TRANSMISSION FLUID LEAKS AT RADIATOR - VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION AND TRANSMISSION OIL COOLER IN RADIATOR END TANK:
http://www.explorerforum.com/forums/showpost.php?p=2575927&postcount=2
TSB 04-22-11 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTC'S) P0172, P0175, P0171 AND/OR P0174 - 4.0L SOHC ENGINE - VEHICLES BUILT PRIOR TO 10/4/2004: http://www.explorerforum.com/forums/showpost.php?p=2587600&postcount=4
TSB 05-22-12 BUCK/JERK AND MISS DURING DRIVE CYCLE ABOVE 3000 RPM - NO DTC - 3.0L 2V GAS AND FFV ENGINE: http://www.explorerforum.com/forums/showpost.php?p=2642162&postcount=4
TSB 08-19-6 HIGH PITCHED SQUEAL NOISE FROM THE REAR AXLE AREA - BUILT ON OR BEFORE 7/28/2008: http://www.explorerforum.com/forums/showpost.php?p=2646171&postcount=2
TSB 07-5-13 DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE.
TSB 05-16-11 SAFETY BELT RETRACTION SPEED: http://www.explorerforum.com/forums/showpost.php?p=2763317&postcount=4
TSB 15406 BACK GLASS WIPER SKIPS GLASS: http://www.explorerforum.com/forums/showpost.php?p=607196&postcount=32
TSB 07-1-7 Steering - Mercon V(R) Fluid Usage:
http://www.explorerforum.com/forums/showpost.php?p=2843023&postcount=1
TSB 12-2-7 TIN ROOF NOISE - FRONT ROOF AREA DURING RAIN - BUILT ON OR BEFORE 11/5/2011
TSB 97-16-12 AIR CONDITIONING - POOR PERFORMANCE - INSUFFICIENT AIR FLOW THROUGH CONDENSER. LIGHT TRUCK: 1991-93 EXPLORER: http://www.explorerforum.com/forums/showpost.php?p=1698904&postcount=8
TSB 01-19-7 •ENGINE - 4.0L OHV - CARBON KNOCK ON ACCELERATION.
•NOISE - CARBON KNOCK ON ACCELERATION - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY.
Status
