Buffalosports
- March 9, 2008
- Buffalo, New York
- 1998 Sport - 4WD
Installing Aftermarket Fog lights (in factory location). The how to..
Note: Before starting, try to figure out which wire is positive. You can do this with a multimeter. Mark the + with a marker. However, this usually isn't important with lights. If it is a problem in the end, switch the two wires going into the light.
1.) Disconnect all wiring to factory Fog Lights. Take out bulb.
2.) Break out Factoy Lights. The lights are glued in. In my case, one broke out by itself. The other I broke out using a chisel.
3.) Drill holes where needed and mount bracket. You may use sheet metal screws but I went with bolts because there is less of a chance of them backing out. Also it decreases the amount at which they bounce, while going over bumps.
4.) When both holes are drilled, mount the bracket. (Before doing this you may want to tape off the bumper and spray paint your assembly)
5.) Mount the Light onto the bracket or however you plan on mounting the light.
6.) Cut off the old adaptor from the factory lights (located at the end of the existing wiring) .
7.) Cut back the rubber protector around the wiring. This is there to protect the wire, so only cut as little as possible. Tape this back closed when process is complete. Also strip the wire at this point. Both on the factory wiring and new fog lighting.
8.) Connect existing wiring with wiring to fog lights. This should be done with some sort of crimp that is resistant to water. Usually they have some sort of shrink material. If you do use regular crimps or tie caps, make sure you use plenty of electrical tape. This is to keep water and dust out.
8.) Turn on Headlights and fog light switch. Enjoy lights.
The whole process took me about 2 hours but if I hadn't had trouble with my bracket, it probably would have taken 1 1/2 hours. It is actually very simple.
