steveissteven
- December 31, 2000
- LAS VEGAS, NEVADA
- '93 SPORT
My valve cover gaskets are starting to leak now. Not too bad, just a little bit.
My question is does this cause a vacuum leak? My intake manifold was recently done; it is dry as a bone and does not leak.
Will leaky valve cover gaskets create a vacuum leak causing vehicle to lose power?
I get no codes or check engine light. The Ford dealership says everything looks great.
The problem I have is vehicle has loss of power (especially when cold). When its cold it takes about a full minute to get up to 60mph! As it warms up, however, power gets better, but never reaches its full potential.
Everything in the world has been done to no avail.
1. New VSS (vehicle speed sensor)
2. New tranny
3. New intake manifold gasket replace
4. New radiator / hoses / water pump / thermostat
5. New injectors (about a year ago)
6. New MAF
7. New brakes
8. New Electronic ignition system
9. New FPR (Fuel Pressure Regulator)
10. New fuel pump
11. New O2's
12. New Catalytic Converter
13. New battery
14. New battery cables
15. New plugs and wires
16. New TPS (throttle Position Sensor)
17. New ECT (Engine Coolant Temp Sensor)
18. New Idle Control Valve
19. New Fuel Filter
20. New Air Temp Sensor
I am beginning to lose faith in FORD
Am I missing something... Do I have dirty injectors? I used to run fuel injector cleaner through the tank quite regularly.
I have a 1993 Ford Explorer Sport V6 with auto trans with auto 4x4 engage
It basically drives as if its pulling a load
Any suggestions.... By the way, Ive checked the timming.. it's dead on and have also done a compression test... All cylinders are within 3 PSI of each other. Can't find any leaks anywhere other than the valve cover gaskets. And they aren't leaking bad, only a little.
Suggestions?
By the way my rig does not have an EGR !!! And I don not beleive it has a camshaft position sensor. I have looked repeatedly (Rear of engine on manifold?) But do not see anything...
Thanks everyone!
Steve
2. New tranny
6. New MAF
7. New brakes
10. New fuel pump
11. New O2's
13. New battery
19. New Fuel Filter
Suggestions?
Thanks everyone!
Steve
