GhostTiger
- December 13, 2021
- Idaho
- 2002 Ford Explorer XLT4WD
I ordered this part from Amazon as I know I need to replace the actuator that controls heat vs cool air in the back of my 02 Explorer (AXINMOTOO HVAC Blend Door Actuator 604-202 Replacement for Ford Expedition 02-04, Explorer 95-02, F100 Ranger 98-11, Ranger 95-11, Lincoln Navigator 02-05, Mercury Mountaineer 97-02 https://a.co/d/jkFaFU5) .
I got everything taken apart, accessed the old actuator and removed it. But when I went to install the replacement actuator, I got the rotating shaft in the blend door, but the actuator doesn't sit at the correct angle to be bolted to the blower housing - it's like 15-30 degrees ****ed to the right and up. So if I were to try to screw it on there, it would be WAY too much tension and would just break it. What's wrong here? It's like the part was manufactured wrong with how the shaft and gears are oriented. Please help!
