germaina
- May 1, 2024
- Suamico, WI
- 2017 Explorer, XLT, 3.5L
Hey All,
looking to see if anyone else has seen what I have and if anyone knows if it's a common issue with these motors. I had the infamous coolant leak from the water so replaced with as well as complete timing set. A while later my wife begain hearing a chatter from the engine so I tore it down again and found that the 6mm diameter timing pin in the crank shaft was pretty heavily damged. The timing sprocket had a ton of rotational play. Has anyone else seen this when they had it apart?
thank you,
thank you,
