PopRichie77
- June 14, 2010
- Quakertown, PA
- 2001 Explorer Sport 4X4
I get flashing OD light. Code 0741, the torque locks up when cold but as soon as it warms up, not many miles, it wouldn't lock up. Trans has 125,000 miles and spent most of it's life pulling a 3800 pound trailer, which it did very well. I connected a volt meter to the computer side of the TCS, checked all wiring, replaced the TCS and the EPC both new, cleaned the valve body and change filter and trans fluid. The voltmeter tells me when the computer signals the TCS to activate and I can see by the tack if it did or not. Tried 2 valve bodies from Ebay, updated with new ford EPC relief and bonded plates still had the problem. Put a TransGo shift kit in the original and modified the plate per Sonnax, got some improvement but still had same problem. I then did some thing that I think should have done the opposite but it worked. I removed the small spring, there are 2, from the TCC solenoid regulator valve and replaced it with a lighter spring, one from the Cooler limit valve. After about 40 miles it still locks up but much slower. When it locks it will take full throttle with no slip, 4 or 5 gear. Looking for some insight on the spring change and why it improved the lock up? Also looking for a flow chart for the TCC circuit? A tech at Sonnax said the TCC seal on the front of the pump may be bad, I plan on replacing that next but won't be able to for several weeks, I do have the new type uncut seal ring.
