I started to develop a whine/vibration in my Trac a few weeks ago which wound up being the front right wheel bearing but I have a similiar 1-2 flaring issue.
I’ve been researching the posts on this page for a few days trying to better understand the problems in my own trans and get ideas for potential fixes. I have seen several other folks with identical issues on the forum so I apologize in advance if my questions has already been asked and/or answered directly.
The end-state for me is that I have had a minor 1-2 Flare for about a year now. When it started I took it to AAMCO and they replaced my overdrive and intermediate servo which did not fix the problem completely although it seemed to quell it for a while. Now the 1-2 flare is now a daily, although sporadic, occurrence so I went back to another AAMCO. They replaced the VB gasket (which was slightly pushed out near the reverse ‘piston’ opposite side from the TSB about the 1-2 flare) and ran checks on the electrical components based on a few TSBs. The problem is still there so they are suggesting a complete rebuild. The only error code to ever come up was an “incorrect gear ratio” code but I have only had that come up 3-4 times in the last year and only when I have had an increased load on the engine/trans during the 1-2 shift.
So I am looking for opinions on whether a new (remanufactured,
http://www.valvebodyxpress.com) VBX type VB would be a probable solution or if a complete rebuild of the entire transmission is really necessary. I have done a lot of other “dry” mechanical work on my truck (i.e. brakes, wheel bearing, lots of electrical additions, ect) but other than installing an aftermarket trans pan and a new filter I have no trans experience so I need some help.
The AAMCO guys did not replace the EPC because they said it tested fine on their equipment even though I pre-authorized a proactive swap of the part as a troubleshooting measure. Leaving it in at 93,000 seems contrary to a lot of opinions on this board so I can’t help but question whether or not they are just “hoping” that a $1700rebuild is deemed necessary.
I'm in the military and I am in a little bit of a time crunch to get it fixed and drive home for the holidays before my next trip so I am willing to spend a little more to save time if it makes sense (i.e. buy a rebuilt VB instead of doing it myself)
Any thoughts on the best course of action?
Vehicle stats:
2001 4WD Trac
5R55E
93,000 miles (a few 1000+ mile trips towing a single bike trailer)
Trans fluid and filter changed at 35k and 90k (Mobile 1 synthetic trans fluid with generic filter from auto zone used both time, O rings installed!)
I have always driven it fast on the HWY but I generally do not accelerate hard from stops or abuse it in any other way.
Thanks in advance
