derangedone
- August 14, 2013
- IN
- 1992 ford ranger STX 4x4
Hi I am starting a new thread here as the new one was getting to be a cluster and I know a little more about what is going on now. I thought I was having a torque converter lockup issue and may still be but after lots of testing and reading I know now that I have no 4th overdrive gear and the torque converter may only be soft locking. I do have a Rear antilock brake light on, however I have tested the purple wire w/ yellow stripe off the pcm and the orange one for 3-4 shift. Both appear to be getting 12.4V until the PCM kicks them on then I get 0.42V Is this correct and the way it should be? I have unhooked one solenoid at a time by cutting the wire on the fender well, I did not notice a difference with the 3-4 solenoid disconnected. I did notice a difference when the tcc lockup solenoid was disconnected though, the rpm's were around 200 higher, however when I let my foot off the gas at 60mph the engine falls to a idle instead of keeping up with vehicle speed?????? Things I have done to fix this issue is= I rebuilt the valve body " it was extremely clean and every valve was removed effortlessly", installed shift kit and new boost valve, new TCC and 3-4 solenoids, I have tested the wiring on fender to the solenoids and got .26 ohms. " cause I failed to test wire harness under trans pan" The truck runs about 2700 RPM or so at 55mph I feel the torque converter lock in and thought it was possibly the 3-4 shift but it isn't, hardly anything happens when shifting to drive from OD I feel a little jolt I figure it is the TC. I have tested engine with my Actron111 scan tool several times with no engine codes, it knows the vehicle speed and the rpm. I have changed the VSS in the rear diff in a attempt to get rid of the rear anti lock light but if this was causing a issue the pcm wouldn't send a signal from 12.4V to 0.42V would it? The only thing I can think to do now is pull the OD servo and see if it has a issue? Could the Servo for OD if it is bad also cause the torque converter no not lock all the way or will a torque converter only lock all the way in OD? It has me confused cause it seems like 2 different issues and that is usually a electrical issue but I know for sure the 3-4 isn't working. If I remove the Servo I am probably going to be cutting some exhaust pieces cause they are not going to unbolt I can tell ya that much This is also a Jasper transmission and I have no idea when it was installed. everything that I saw inside looked clean and no broken pieces in the pan " a little grey gunk on the magnet but fluid isn't burnt. What would you guys do? looks like the cats are about 2" away from the OD servo!
