sne43
- April 15, 2009
- Minnesota
- '97 XLT, 4.0 6 Cyl., SOHC
My '97 ex developed a grinding noise. I found lubricant in the passenger side rear wheel/break area. Took it to my local shop. They indicated it was probably the seals, but would need to look into the noise. They used a stethescope and isolated the noise to the rear differential. Given the high miles, and my not wanting to spend too much asked them to just replace the axle seals and fill with new lubricant and an additive that they felt might help the noise. Upon getting in there, they cant get to the seals because the Differential Pinion Shaft Lock Bolt broke. This is common. They charge $400 to pull it out and quoted $800 for the total job. They will not guarantee that the noise will be gone. Thoughts?
