tagtifftj
- December 31, 2008
- corvallis, oregon
- 1994 4x4 auto 6 cyl Explr
hi, i just got this two weeks ago. I have a 1994 4x4 automatic Ford explorer limited and have low oil compression. If you were filling up your gas instead of looking at your oil pressure you would find that my oil pressure sits at 1/4 tank. Sits on the first letter. Very low. I have a constant check engine light on with these codes.332 EGR Valve opening not detected. 335 EGR(EPT) Sensor voltage out of range during self test and 341 which is octane adjust service pin in use.
I got this vehicle 2 weeks ago and this is what i have done to it. I have changed all plugs wires, still need to change spark plugs. Fixed Radiator leak, fixed vaccuum leak, and check engine light still on, found vaccuum leak at back of engine when changing plug wires, changed both crank cases had them flushed and changed oil and put oil in for older motors. please, someone help. am single disabled mom with very little money to fix. can anyone tell me what they think it is and give me any cheap fixes? live in corvallis, oregon. thankyou tagtifftj also slight hesitation at idle. thank you
Please, i dont know how to use this website, and im getting lost, i hope you can help me. desperate single mom
