MANZ
- September 5, 2001
- Olney, MD
- '94 XLT
Today while out on lunch break, my engine just quit all of a suddden on my '94 XLT. It was obvious that no fuel was getting to the engine as I tried to restart it. When I turned the ignition off and then back on I could not hear the fuel pump start up and build pressure like it normally does. I then checked the fule pump cut off switch but it hadn't tripped, so I checked the fuel pump relay under the hood. I smacked it a couple of times and jiggled it around in the fuse box. It then started back up and runs fine so far. Does this sound like a bad relay or just loose connections? Is this a common problem?
