mrlucas
- December 3, 2009
- CA
Hello All. I am a new member and have a problem 2004 Explorer giving codes P0191 & P1233. I have identifed what the codes mean, but not how to fix. I took it to a mechanic last week with no check engine light or known code, it has been "hard starting" and gradually getting worse. It was intermittent and when it occurred it would generally start on the 3rd try (have not touched the gas pedal). The mechanic charged me $100 for diagnostic, said he found 3 codes though I don't know what they were, and cleaned a few things. He said he could not replicate the problem. He said he cleaned a few things and and through all the TSBs and the only thing he might reccomend would be to change the fuel filter.
Well, it has gotten much worse since then. It in fact had an issue with the starting when I went to dpart the mechanic's, nothing was fixed or diagnosed. Now difficult to start every time and sometimes lugs when it does and the check engine light came on. i have my own code reader and got P0191 "fuel rail pressure sensor circuit range/performance" & P1233 "fuel pump driver module off line". Is there a sensor that needs replacement or the fuel pump? Would a fuel filter make a difference. Please help.
Thanks, Shane
Thanks, Shane
