MrShorty
- December 27, 2001
- Spanish Fork, UT
- 92 XLT and '87 Bronco II
Took my Explorer into the shop on Saturday to get the alignment done (replaced bad ball joints a few weeks ago). The caster and camber were off a little, so I had him tinker with the shims until he got those right, then he did the toe (presumably). When he got done, I asked if he had printed out the final numbers off the computer. He said, "no, but I can tell you what they were." So he told me and I wrote them down on my sales ticket. Camber and Caster are now within specs, but he told me he'd set the toe to +0.2 in. on each side. That didn't seem right to me, so I went to the library to look up the specs in Mitchell. As I said, camber and caster are in specs. But the manual says that toe should be ±0.13 in or ±0.25°. If we give him the benefit of the doubt and say that he said, "inches" when he meant, "degrees", shouldn't he be able to get it closer to the listed ideal of 0 when setting the toe? I suppose I should also ask if there have been any changes in the alignment specifications for a '92 Explorer in the last several years.
I plan to take my truck back in and have him try again. I figure I paid him ~$100, I should get a proper alignment. Just give me the necessary information so I can go in and tell him that I want to try again.
