97V8,
You are wrong. Pre-ignition and detonation are not the same thing. Pre-ignition takes place when an object in the cylinder is heated to the extent that it glows cherry red and this is used as the source of ignition for the cylinder instead of the timed spark. This could be from a carbon build-up on a head or an electrode from a spark plug which is of too hot of a heat range. The spark plug is actually too far down in the cylinder and when the combustion occurs in the cylinder, the spark plug cannot dissipate the heat and cool enough before the next compression stroke and the air fuel mixture ignites from the cherry glow.
Detonation is actually more violent than pre-ignition. When an engine is running, the ignition timing is advanced more as the RPM and acceleration of the engine increases. This is done to compensate for the time that it takes for the air fuel mixture to burn. When an engine is at idle, the time between sparks is less than when running at high speeds so the fuel has more time to burn completely. When at higher RPM's, the timing actually is advanced so that the spark is given well before the piston reaches top dead center (TDC). If the timing is not advanced, the combustion would occur after the piston has reached TDC and has started back down which would result in less power. If the timing is advanced too much, the combustion would occur prematurely and cause the piston to be pushed back down in the cylinder before it reaches the top and causing the piston to actually try to stop and reverse before it is ready to. Thus resulting in detonation. This is what is commonly known as knock. Things that can cause it are, improper timing, low fuel quality, etc. I have actually seen pistons self destruct because of detonation.
Pertaining to the differences in fuel octane, regular unleaded actually burns at a faster rate than premium. This is one reason for knock because the flame front from the combustion is more violent and done sooner and can be excessive when the piston has reached TDC. The higher octane fuel helps reduce the knock because it burns at a slower and more controlled speed.
I hope maybe this has helped to explain the difference. It is not easy to put into words, but I did my best.
Ira
91 XLT 4x4
