imq707s
- July 5, 2000
- Springfield, Missouri
- 1997 Mercury Mountaineer
I've got a 97' Mountaineer with a 5.0 V8 and AWD. It's got about 142,000 miles on it, and the motor is starting to burn quite a bit of oil. I've rebuild several small and big block chevy motors, but I've never messed with any ford motors....and never messed with fuel injected motors.
I figure since I'm going to the trouble to pull the motor and rebuild it....I'd be smart to swap that cam and do some head word to get some more power and TQ out of the motor. I think the stock HP rating for the motor is only around 225HP.....and I know it should be easy to get 275+ out of it. I'm not looking to race it, but I do a lot of towing so some added TQ and HP would be great.
Here are some questions I've got, so if you guys can help me out at all.....that would be great.
1. What is the easiest was to get more power out of my motor? I'm assuming that putting a different cam in it, adding a little compression with different pistons, boring it out .030"., and doing some port work on the heads & intake is a good start. Maybe some headers and a better exhaust (it's still all stock). Am I on the right path.....or should I be doing something different?
2. If I do a cam swap...what cam would you suggest? Keep in mind, bottom-end power and TQ is what I'm looking for. A slightly lopey idle would be a bonus
3. I'm assuming that after these mods (what ever they end up being), I'll need to send the computer somewhere and have it reprogrammed (right??). Who should I send it to?
4. My truck with the worn out 5.0 is only getting about 12MPG around town, and about 15MPH on the highway. Is it possible to do some mods, get more power, and still get better MPG whan what I'm getting now?
5. Another option....instead of a cam swap and head work....would I be better off just doing a stock rebuild and adding one of the supercharger kits from Explorer Xpress?
6. What is the best place to go to for getting the motor parts?
Any other info you guys could give me would be great. I want more power, but I also want a reliable truck that I can drive every day that won't drink tons of gas!
Thanks for the help!
