crum2243
- November 10, 2003
- San Francisco, CA
- 03 EDDIE BAUER 4WD
I have the code PO141 - O2 Sensor B1 - S2 - I have a 96 Explorer with the V6
I need to replace this oxygen sensor after researching this site. I find out that this would be the passenger side sensor farthest from the manifold (S1 being closest to the mainfold)
After checking my Chilton it says that the 96 had 4 oxygen sensors but after crawling around under the truck today I can find only 3. One on each manifold coming out of the engine and one on the exhaust just after the cat converter.
Autozone website shows 4 sensors but I can't find the 4th.
Where are they all located and which one is the B1-S2?
Also Autozone shows them all to be the same type but it looks like the one behind the cat is different than the two off the manifolds.
Thanks for any help.
