You may want to get the door panel out of the way so you can work on the speaker--
Before pulling the door panel off, you can remove the window/mirror switch unit by inserting a small screwdriver at the base and gently prying it up and working it out of the door panel. Then use a phillips screwdriver to remove the two black screws that attach the window/lock switch to the little faceplate. You don't have to disconnect the wiring harnesses, just separate the switch unit from the face plate.
Take out the three screws, and use a small screwdriver to pop off that little black trim piece at the inside door handle-- you may have to pull the handle to the open position to slide the trim piece off.
Next, pop the door panel loose and lift it off of the window "sill". As you do this, angle the window switches and face plate so they'll slide through the opening in the door panel. Now the wires for the door light and the automatic-open window control unit are still connected to the panel. With your phillips screwdriver, take out the one screw that holds the little black control unit to the door panel (or remove the connector-- I find it easier to take out the screw. The door light is really easy-- gently twist the connector and the thing will pop out bulb and all.
All this sounds fairly complicated, but it can be done in less than two minutes. (My window gets stuck occaisionally, so I have to go in their to free it up.)
