El Duque
- August 12, 2002
- Lake Hiawatha, NJ
- 2010 Eddie Bauer
I just bought a 2008 Explorer and noticed that the drivers side armrest was very squeaky, when opening and closing the door and also over bumps. So I pulled the door panel off and slapped some thick grease on the metal brackets which slide into the door itself and was causing the squeaking.
The procedure was
-pop off the plastic cover on the side of the armrest/switch box/door handle assembly
-lift the switch box out of the main assembly, I used a small screwdriver
-unplug the connectors from the switch assembly
-unbolt two 7mm bolts located next to the door handle, you don't have to remove the bolts all the way
-unbolt two 7mm bolts on the bottom of the door panel
-now the door panel will lift up and off
I then unplugged the power mirror connector and had enough room to work. No more squeak!
Hope this helps someone else
The procedure was
