Sid Daley
- January 6, 2003
- Surrey B.C.
- 97 XLT Sohc
Initially I was under the impression that this would be a much tougher job then it turned out to be. I had heard that it was much easier if the axles were pulled, as it turns out if you have ever done a drum brake job before it's not much harder. The axle flange makes it a little tight to work but outside of that quite a easy job.
I created a emergency brake repair PDF from my Ford CD and if anyone would like it simply email me at sid_daley@yahoo.ca with "emergency brake" in the subject of the mail and I would be glad to send it to you. It's quite a small file 215k.
Back yard mechanic difficulty rating 5/10
Btw: The old pads were down to metal, almost like the pads disintegrated, probably never changed so they lasted 6 years.
Sid
Sid
