trailguy52314
- May 13, 2002
- Kealakekua, HI
- 01 Sport Trac
Lift on 2002 edge
I have installed the trailmaster lift made for the Ranger FB120. Which is for the 1998 4x4 ranger on my 2001 sport trac. I have since changed the steering slide system to the superlift longer spindle set up for the 2001 sport trac. To get the spindles I had to purchase a complete superlift sport trac kit. So while we were changing the steering I replaced the stock spindles, and the front crossmember with the superlift parts. I was wondering if the left over superlift parts in the sport trac kit can be installed on a 2002 ranger (any other vehicles?) along with the other trailmaster parts. The trailmaster parts that will be installed are the steering slide system, rear add-a-leafs, and front crossmember. The superlift torsion bar drop down brackets, back crossmember and front differential bracket will be used. What do you think is a good price for this lift set up. The tralmaster parts are about 1 year old and the superlift ones are new never installed. I will also be selling the superlift shocks with the lift. The only problem I see with this kit is that one of the Trailmaster steering brackets are bent can these be purchased from Trailmaster? And what needs to be done when you sell a lift like this? Thanks for any and all the help.
