trashtruck
- December 31, 2015
- Points
- 28
- capital district, ny
- 1992 explorer xlt 4x4
as the engine cranks, the crank sensor should supply voltage to the icm on pins 4 & 5. the crank sensor may supply ac or dc voltage, i can't remember. the icm should then supply voltage from pin 4 to the pcm, pin 16. the pcm would then ground pins 58 & 59 to fire the injectors and send spout signal back to icm on pin 2. this is my understanding.
