Buttsy
- July 17, 2006
- Papillion Nebraska
- 2002 4WD XLS/2004 4WD XLT
Since I changed the front pads about a year ago, I've had to remove the caliper every 6 months (today for the 2nd time) due to a rubbing noise when applying the brakes. What I've found each time is that the caliper won't move and the grease on the caliper bolts has dried up/disappeared. I put a good deal of good quallity grease on, make sure the boots are in good condition, and tourque everything to specs. Once I clean and regrease the bolts, the noise is gone. Any ideas on what I'm doing wrong? I'm doing the rears tomorrow for the first time and I don't want to have this same issue on the rear. The only other issue I've noticed is my brake fluid is extremely dark/probably contaminated so I'm bleeding the lines this week.
