Jcain
- August 22, 2010
- LaCrosse, WI
- 2000 Mercury Mountaineer
I have a 2000 Mercury Mountaineer AWD 5.0L and have been working on this dang vehicle for 2 weeks now. I changed the wheel bearings, new brakes, oil, etc. I also determined that my u-joint on the front drive shaft was bad. I bought a new U-Joint and removed the front drive shaft. My plan was to leave the front drive shaft off so that we could have a drivable vehicle while I fix this u-joint. Anyways, I got the front driveshaft off and I have two questions about removing this.
1.) (MAIN PROBLEM QUESTION) The area where the front drive shaft attaches to the u-joint, there is still the part where the u-joint was attatched (see pictures 1,2 and 3) When I drive the vehicle now, this thing rotates super fast as it is supposed to when the driveshaft is attached via the u-joint. However, without the drive shaft attached, it makes a really bad noise when being allowed to spin freely (a loud thunking sound and increases in frequency the faster I drive). Can I take this part off? This is definitely the part making the noise. I just need a working vehicle for the immediate time for my wife (clank free) until I can get this thing put back together with the new u-joint.
Picture 1
Picture 2
Picture 3
2.) The area where the driveshaft attaches to the transfer case, there is a ball joint thing. The driveshaft was removed with half of this bearing attached and the other half is still attached to the transfer case. Should I remove the other half from the transfer case or reattache the half on the driveshaft or is it okay to leave as is? See pictures 4 and 5 below for this. Thankyou Very Much!!
Picture 4
Picture 5
Picture 1
Picture 2
Picture 3
Picture 4
Picture 5
