Dennis J.
- December 20, 2019
- SALISBURY
- 2014 Ford explorer XLT
Hello gentleman,
First time poster, but I've lurked for a little while.
My wife's 2014 Explorer has the 3.5 NA engine. It had the Infamous weep hole leak, and with 160k on the odometer, I went ahead and changed the timing chain and guides along with the water pump.
After reassembling everything I got a P0019 code (camshaft/crankshaft correlation bank 2 sensor 2). I had watched the Cloyes video on changing the timing chain and they said "you don't need the cam lock tool". I'm kicking myself in the butt for not getting one.
Well, I have a set now, and you can see in the picture that it looks like the exhaust camshaft is one tooth off from being matched up with the other 3 camshaft.
I couldn't find any info on it, so before I dive in any deeper, I wanted to see if anyone knows of a way to adjust that cam/sprocket without having to remove the timing cover?
It's raining out right now, so I figured I'd see if there was some way to save myself from emptying the fluids and breaking the seal, just to pull the phasers and reposition it.
Thanks guys for any info or tricks you may know!
