- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
A window crank? hahaha classic!!
RangerX said:Guy, I searched and found the pics Rick took of the shift mechanism on the McNeil Explorer at Truckhaven the other year.
http://www.explorerforum.com/data/showphoto.php?photo=8367&sort=1&cat=500&page=2
T-case hookup, very basic. They welded a bolt onto the shaft!
SuperEx91 said:Couldn't you just use a 90 degree gear like on page 2 and weld it to the triangular shift rod thing and then make a bracket to solidly mount it and then weld a rod to the other gear and run it up to the cab? it would only require it to turn what it would take if you used pliers. I think that would be reliable. And actually if you could find a gearset the had like a 1:2 ratio you would only have to turn it part way. that would be awesome. you could make a fancy bracket in the cab and label it. I just might have to try it but i dont know where i could find that kind of gearset.
I am building this setup right now for my Ranger truggy. Looking good so far!
