- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
I've been running the spring setup for 15+ years
I have an ARB locker and NO C CLIP
First I welded the dust cap in the slip yoke and ran the spring inside the yoke. After 3-4 attempts at that setup (would last a year or so until the spring collapsed or I blew out the dust cap)
I modded that setup a few times and it worked very well....but once in a while I would have to fix it.
Now I am running the spring setup shown above, using the Echo weed whacker spring and it works AWESOME
I have a shock boot covering the whole thing, which also fit perfectly.
I have heard that some lockers will allow the C clip, some will not. I have a 93 explorer dana 35 and early ARB locker..and could NOT fit the C clip, whereas my friend Brett has an ARB and his d35 ttb DOES have the C clip? Something about a later version of the ARB.
I actually prefer to NOT have the C clip because it makes servicing the pass side axle shaft U joints, slip yoke, and diff seal SO MUCH EASIER.
The spring holds the axle in the diff very very well.
In Moab in 2007 I think it was I hit a whoop going a little to fast and my pass side shaft assembly came apart broke the yoke. With no way to fix it on the trail I just zip tied the axleshaft to the beam and ran the next 6 days without a pass side axleshaft. No problem.....I still had 3wd
