Exproblems
- April 17, 2011
- Orchard Park, N.Y.
- '05 Explorer XLT 4.0L
I'm looking for any ideas as to why my 2005 4.0L V-6 Explorer engine won't start up this morning. I went to start the vehicle and during the startup process with the key in the run/start position, I thought I heard a brief sound like a small "poof" or backfire and the engine wouldn't start. I backed off on the key and tried to start the vehicle again and it would just turn over, but not fire up. The starter is working okay, turning the motor over, and I can smell gas fumes in the air after trying to start it a few times. No strange noises coming from the engine as it turns over. I then checked a few fuses under the hood and they were okay. I also pressed the fuel pump reset button for $hits and giggles, but I do not believe that this is a fuel pump issue since I can smell gas fumes coming from the engine compartment, meaning gas is being delivered to the engine via the fuel pump. I checked the battery connections, spark wires etc, all okay. The vehicle had been starting and running fine since I bought it 2 + years ago. No unusual dash lights blinking on and off during the start up process. I will try to start it up again in a few hours since the engine probably got flooded by fuel trying to get it to fire up. So far all I could find in the forum as to the problem is possibly a "Crank Shaft Position Sensor" or a problem in the PATS system and I don't think the latter problem applies here. I'm going to have it towed up to my mechanic in the morning if it doesn't start later this morning.
Thanks to anyone that can give me some insight as to what this problem may be.
A few hours have passed by and I tried to re-start my Explorer and had put the battery on a charger for a few hours as well. Engine turned over, but would not start. After the 3rd try or so to start it, I noticed the engine spun slower like a huge drain of power, and after I switched off the ignition, I noticed the gauge needles for the RPM's and MPH's dropped below zero and rattled back and forth quickly for a few seconds before settling down at zero. I also saw a single word message on my message screen when the gauge needles were rattling and it said "Test". Don't know what the Test was for? Does anyone know what this is or means? I also pulled more fuses for the ignition, fuel pump and starter and all were good. I also had a neighbor turn on the ignition for me and I listened for the fuel pump to kick on and I heard a "clicking" sound by the gas tank. Tow truck is on it's way to my house as of right now. Dropping truck off at my mechanics shop. Thanks again for all who can help with this matter.
