so i have everything installed for my cb system. Firestik 4' antenna, cobra radio, and 21' high quality coax. I located the antenna off the back above the passenger tail light using the firesik widget swivel mount. Now, the question at hand is, where should i be getting continuity for a ground, and where shouldn't i? for instance, should the bracket be grounded, and should the base of the antenna be grounded? i read somewhere that if you have the antenna grounded improperly you can kiss it goodbye, and i dont particularly want to do that haha. Thanks!
