Info: Serious Explorations Glossary
xxScapegoat
Hesperia/Victorville, CA
2001 XLS
I decided to make a glossary of all the "slang" being thrown around on this site. I know when i first got her, it took me a long time to realize what you guys were talking about. Hopefully this will help out the people that are just as mechanically unlearned as i am. If i forgot anything please add it.
1st gen - 1991-1994 Explorers
2nd gen - 1995-2001
3rd gen - 2002 - 2005
4th gen - 2006 - 2010
5th gen - 2011+
IFS - Independent Front Suspension
SAS - Solid Axle Swap. Replacing the IFS suspension on a newer truck with much stronger and durable strait axle. Articulates far more as well.
SOA - Spring over axle
Locker - Carrier in axle where both wheels recieve equal amounts of power all the time.
TT - Torsion twist. Tightening or loosening the torsion bolts resulting in raising or lowering your explorer.
Suspension Lift - Increasing height of a vehicle by dropping suspension components down from stock location.
BL - Body Lift. Putting spacers between the body and the frame.
AAL - Add a leaf
OEM - original equipment manufacturer
Shackles - Used to connect your leaf springs to the frame of your vehicle. Gives you added height in the rear ( usually used with TT)
GB - Group buy.
PA - Performance Accessories (www.performanceaccessories.com)
HID - High intensity discharge. The really bright lights you see on cars that almost cause you to swerve off the road. :p
BFG - BFGoodrich tires. Combined with:
MT - Mud terrain, or
A/T - All terrain
hope this helps
edit: i know this isnt a previous thread, but it seemed to fit here best
Well done. Wish this was around when I joined 9 months ago. :thumbsup:
MAF = Mass Air Flow (sensor)
IAC = Idle Air Control
ECU = Car Computer hahah forgot what it stands for exactly
BTW-by the way great idea
WTB = Wanted (err ing?) to buy???
FS = For sale?
im unsure of WTB, i keep forgetting when i figure it out..
WTB = want to by
NOS = Nawwwws
FMS = Ford Motorsports
SoCo = Southern Comfort (100 proof or nothin)
Robb said:
A glossary?
well yeah... a dictionary is alphebetical with pronunciation and other crap. a glossary... well ...isnt.
edit: maybe we can get a moderator to compine all meanings from both threads and make it a sticky?
IIRC = "If I Remember Correctly"
I think ;) I had to google it because I had no idea what it meant 2 minutes ago.
IC -Instant Center (The instant center is the intersection of the LCP and a line drawn from the rear tire contact patch as viewed from the side.)
IC Height -Instant Center Height (measured from ground to I.C.)
IC Position -Instant Center Position (measured from center of rear axle forward to I.C.)
LCP -Link Convergence Point (The intersection of lines drawn from the top and bottom links as viewed from the side.)
-Roll Center (The roll centre is the point that the body wants to rotate about on the axle or the point that the axle supports the body laterally)
-Roll Axis (The line drawn through the two L.C.P’s is the roll axis.)
COG/CG -Center of Gravity (top bolt of your bell housing is a general rule of thumb)
WB -Wheelbase (center of rear tire to center of front tire)
AS -Anti-Squat % (COG Height * IC Position)/(WB*IC Height)
C/O -Coilover shock
This all has to do with double triangulated 4-link suspensions and will have no meaning for 95% of people here. :confused: :D But I've been doing alot of research lately. ;)
Oh, and one for the supporters of the site:
EE - Explorer Express
Already been done before. CLICK
Robb is a moderator! Represents VA very well!
-Drew
I just moved this thread to Under the Hood and Drivelines where it can be posted to.
IMO-Im my opinio
IMHO- In my humbe opinion
Heep-Jeep???
Those really confused me when i joined
-Drew
Ah, I mock the word represent:
Repa'sent! Repa'SENT! :p
PCM = Powertrain Control Module (aka computer)
HCU = hydraulic control unit (re: brakes)
Hootus = see the other dictionary thread haha
yea what beau said soco and mountain dew lol good
what do they mean when they refer to their truck as " my x " or "x" is that just short for xlt? or is that a generation?
...X as in Project X or just my X is a short way to type out = Explorer...:D
...if you type ex, people think ex vehicle, g.f., etc...;)
I thought that was the case but wanted to make sure. Thanks for not making this NOOB sound like an idiot. :D I have found this site to be most helpfull I've never done a build up of a ford before. so I am just getting down the lingo and searching out parts. This site has it all if you take the time to look :thumbsup:
EB= Early Bronco or Eddie Bauer depending on usage.
Top Bottom
