- March 4, 2007
- anaheim hills,california
- 95 ranger 4x4/ 91 X 4x4
...One of my Customers told me they were taking their 2010 Lexus GS350 4dr sedan in for it's 15,000 warranty service...
...I saw them later today and they told me it cost $450 bucks plus tax...
..They told me that Lexus did the first couple services for free but now it's in the charge phase so I thought I would post this up to see what others think as if this is normal in todays market..
..This was a scheduled service appointment, nothing special.
The following is whats listed on the bill
________________________________________________________
..The service they performed is called "MPI World Class Inspection". Note that it also says "Set tire pressure to OEM specifications"
Perform 15,000 mile service_____________$260 (Lab-Mechanical)
Service done
Replace engine oil and oil filter
Rotate tires
Road test vehicle
Replace engine air filter
Replace A/C cabin filter
Replace wiper blade inserts
Add fuel cleaner
Re-torque drive shaft flange bolts
Inspect and measure brake pads and rotors
Inspect and test battery
Inspect
axle shaft boots
Ball joints and dust covers
nuts and bolts on chasis and body
brake lines & hoses
engine coolant
exhaust pipes and mountings
front and rear differential oil
rack and pinion assembly
steering linkage & boots
Parts Cost____________________________________$147.01
replaceable element $7.88
gasket $1.70
element sub assembly, AI $42.00
EFI cleaner $8.95
oil conditioner $6.95
w/shld fluid $1.95
parts clean $3.99
rubber wiper blade $9.32
rubber wiper blade $12.20
cabin air filter $52.07
add the following
7 qts syn blend 5W20 $42.00
..So that totals up to about $450 plus $15 tax..:scratch:
..Their question to me was, "Can this be done cheaper elsewhere and would it affect their vehicle warranty?"
..That is the question I propose to you all..Will any other service of this vehicle void it's warranty or are they stuck payong an arm and a leg for this..
..I buy used and do all my work so I guess I am totally out of touch and these new warranty/service agreements..
Service done
Rotate tires
Road test vehicle
Add fuel cleaner
Inspect
axle shaft boots
brake lines & hoses
engine coolant
gasket $1.70
EFI cleaner $8.95
w/shld fluid $1.95
parts clean $3.99
add the following
