koda2000
- September 2, 2011
- x
last month my oil pressure sending unit went nuts on my '01 xlt. the needle bounced around so much it managed to get it under the little pin it's supposed to rest on. as such i've had no pressure reading because the needle couldn't move. i know how to remove the instrument cluster and could have done so to fix the needle, but this truck isn't worth the effort to me. instead i drilled a small hole in the cluster face with a step drill. then i used a hooked pic to lift the needle over the pin. to plug the hole i took the top off a BIC pen, painted it low-gloss black and pressed it into the hole - problem solved the redneck way.
