- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Solved Ford 4R55E Transmission removal & installation instructions
How-To: Adjusting Transfer Case Shift Linkage (Manual Shift T-Case)
Transfercase linkage retainer clip fix
Speedo Drive Gear Primer
Transfer Case and Hubs - How To Articles
Differential - Rear Axle - U-Joint How To and Information Articles
General Transmission Diagnostics - Maintenance - and Information Articles
Manual Transmission and Clutch How To Articles
A4LD - 4R70W - 4R44E - 4R55E Transmission How to Articles
5R55W - 5R44E - 5R55E Transmission How To Articles
How to: - Repair Manual for 5R55W, 5R55S, and 5R55N Transmissions
So I came across this today. Really great info with full color pictures. It's the full repair Manual. Also, it has all the OBD2 Codes at the end. I figured others on here would like to have this and I should share the file. I wasn't sure if I should post it under a different forum but I figured...
www.explorerforum.com
