First pics of disassembly
The job started with setting the front end up on jackstands, as you see. We then proceeded to tear the front end apart, and a high powered impact gun made it real quick. Everything had been treated with penetrating oil prior, and some parts, namely the axle pivot and radius arm nuts, had been treated all the weekdays before. So, here we go:
This is the full frontal view underneath, with all of the parts out. We started at the rotors, followed by the spindles, and there is special tool (slide hammer) used to pull the spindle off of the knuckle. The brake calipers were left intact, suspended on bungees. Check out the Performance Products 3" Lift coils, and the U-joint of the front drive suspended in the breeze... And do you see how dusty red the front and underside of the mill/undercarriage are? That was the water pump telling me it was about to meltdown...
After the spindles were off, we removed the front half-shafts, just removing the boot clamps, marking alignment of the starboard spline with the stub out of the front pumpkin, and pulling them out of the pumpkin.
Once the axles were gone, the ball joints and knuckle were next, going from top down with the
C-Tool. The I-beams were then supported with a second set of jackstands, and copious amounts of torque were unleashed on the radius arm nuts and the bolts at the I-beam...getting the long bolt off of the top took creative tooling, as we did not have the correct metric socket with a deep well to grab it. We did get them off, and removed the coil springs.
Next was the shock mount nut, which came apart without difficulty...a week's worth of treatment with penetrating oil saw to that. Now, with the bolts anchoring the radius arm to the I-beam gone (oh, and the sway bar brackets came off with those bolts), we finished removing the radius arms.
Now, for the REAL Showstopper: When we removed the radius arms, on the starboard side, this is what we found:
And the bracket that this radius arm went through came out like this:
Here the fun began, Port side was fine, showing a normal amount of wear, but it's bushing was pretty well shot. The Starboard bushing was loose on the shaft and in the socket. More on this part later.
On to the I-beam axle pivots. They succumbed to the impact gun fairly quickly, and we dropped the I-beams out gently. With the half-shafts out, it made it easier, but the port side carries the pumpkin, and that we had to manhandle.
Now that everything was out, cleaning, painting and reassembly could begin. I started with what I couldn't take off, the flaking rusty shock towers.
This is the starboard wheel well, sans fender liner, as it would've gotten in the way. Scrubbed was I could off with a wire brush, shot the tower with Rust Converter, and covered it with hammered silver Derusto.
Port side, same treatment. You can see a bit of the hammered silver overspray on the frame rail behind the tower...
Now, a bit closer:
In this, not only can you see the tower, you can see the sway bar dangling in its brackets, which I welded gussets on to keep from bending, and those are Prothane bushings in the bracket. I need to get a new swaybar, the 31X10.5 tires rub this one when the steering is at the locks. A rollover in 1999 is still revealing itself...:roll:
So, this is the disassembly of it.
Now that the major work is done, I think that I can do a better job documenting the rest of it.
