cyazee
- July 14, 2002
- long island,ny
- 94 explorer xlt
120k on pushrod XLT. Intermittant ABS light on about 2 weeks . Got a scan tools that does ABS.. It showed 3 codes for right front sensor.. Took the rotor off, fins inside rotor and sensor were very dirty. I cleaned them and went to Boston, no problems.
On the way back intermittant abs light ,right wheel heats up caused by caliper not releasing. Put new caliper, brake line, set of pads (old one were burned)on front. Bled fronts, on my merry way.
20 miles later same lockup is happening. R/f wheel is hotter than left, left is hot, both calipers are not releasing.
Spoke to mechanic he states abs is problem. I removed the two cube ABS relays and two ABS 30 amp fuses from power box and drive.. Calipers are released, wheels cool and "ABS" light in dash on.Mechanic says brake fluid is very dark.
The XLT is running good save abs. What should I do?
