macknos94
- December 13, 2007
- Harrisburg, pa
- 2003 mountaineer premier
ok so my lawyer finally got back to me about but rear glass and rear panel cracking by the ford/ mercury emblem. ford is really close to opening a recall on the rear glass and the panel. all you need to do if you have this issue is call he ford hotline and make a claim you need your VIN, your name and other info like that. state the issue and that's it.
my lawyer actually bought a 2005 mountaineer and has the same issue. he called ford and reports it the lady kinda slipped and released that they are getting huge numbers of calls with the same issue between the explorer, mountaineer and aviators. also if this keeps up they will be forced to do a recall and basically fix the issue. and the only fix is the 4th gen rear hatch so if you are interested in get it fixed for free call asap. it only took me about 10 minutes to do
also they are getting many reports of the rear glass exploding violently for no reason. the samething that happened to mine
