shaker1
- March 6, 2003
- Algonquin, IL
- 2006 Explorer XLT 4X4 4.0
Mine quit working after 4 years & 44,000 miles. Unfortunately, I ordered a new unit before I removed and tore into the old one.
What I found was that the main wiper shaft had frozen, due to the elements, into the 2 inch brass sleeve it rotates in.
After removing the assembly from the vehicle, remove the black stamped steel cover that is held by 8 T20 screws. Next tap the shaft through with a hammer and a punch. It will eventually push through with the two large tooth gears still attached. I removed the gears, but you may not have to. Then I cleaned up the shaft with some WD40 and 400 grit sandpaper. And I sprayed copious amounts of WD40 through the brass sleeve. Then I put anti-seize on the shaft and ran it in and out from both sides several times, wiping away the excess WD40. Then I reassembled it with anti-seize on the shaft and under the little plastic bushing at the outside end of the shaft.
Take note of the gear tooth orientation and do not lose the o-ring that sits beneath the plastic bushing on the end of the main shaft. Also, notice there is a plastic cap/bushing on the inside, capping one of the shafts. Do not lose this.
I tested mine with a 12v source to the red and black wires on the white plug. It appears to be working fine, although I did not reinstall it for a complete test.
I wish I would've done this before paying $170 for a new unit!
