- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
As a vehicle ages, things start to go such as lift support shocks. They are easy to replace, and don't require special tools. All you need for this task is a Vice Grip, and a flat screwdriver. They sell several types of shocks for the same vehicle, so make sure that you have the correct ones before you start. The Aerostar has several options because some of them don't have a rear wiper or glass in the rear hatch. I have both options, so the correct shocks for this application have the highest lifting support. This is the set:
Always attach a Vice Grip on the opposite shock before you disconnect the shock that you are working on:
Start with the rear:
Lift the release tab with a flat screwdriver, and pull on the shock:
You will see this on the inside:
Do the same thing on the opposite side. The new shock snaps into place if you apply a little pressure. Never use a hammer or pry on the clips. The whole job shouldn't take more than a few minutes to complete.
