dvdswan
- June 6, 2021
- SEATTLE
- 2002 ST 4WD Premium
I've been mulling over this for some time. Not sure which lift kit would work best for my needs. Obviously, the front is torsion twist but the rear I'm not sure if I want to do the shackle or add-a-leaf. The shackle I would redrill for a one inch lift and if needed to move the support bar up or remove it. The add-a-leaf is generally an 1-1/2" lift. TT would be to match so I don't have the hotrod rake.
I've thought of 1" hockey pucks for a body lift, but I'm not a fan of them. The main reason is issues with having to move lines, wires, linkages, radiator stuff, etc. Too much work for what the need. Plus, I don't like the view of the frame being lower from the body. So yes, it's just personal preference.
I know the more you crank t-bars the rougher the ride up front. Been there done that, not worried about it. The ST isn't going to see much offroading as I have a toy for that. This is just mainly for the look. I am planning on going to a larger tire, preferably a 275/75R16 (32s), current tires are 255/70R16s (30s) I think, whatever the stock larger tires are. If the 275s are too large then 265/75R16s. Wheels are remaining stock aluminum and when I upgrade they will still be stock 16s just a different style.
Looking for opinions/thoughts on lift/tire sizes. Remember, I won't be stuffing the tires.
Thank you for looking.
