suv1
- May 9, 2013
- 98 mercury
HI I'm having an issue where the power windows, interior lights, exterior mirror lights, wipers, door chime, defroster, map lights ,glovebox ,vanity mirror lights all are not working intermintently. car drives normally just no wipers interior lights etc. Ive noticed this happens when its cold outside. I have to run the car heat for 30 min and then everything mentioned above starts working after I hear a click, now its not working even after waiting 30 minutes with heater on. Im thinking its the gem. I did swap the relays around in the black box under steering colum there are 6 small relays and 1 big square relay it tested good I checked fuses behind the door all are good is there a fuse under the hood cause I did not test those fuses my module ends in BA will the BB also work its just the last 2 lettters that are diffrent its a 1999 awd v8 5.0 module is YL2T can I use a xl2t? Please let me know as soon as you can as this just started last week to not work at all but has been working intermitently for a long time ialso recall a traffic safety bulletin
