AP9
- July 23, 2012
- Chicago SW suburbs
- 2000 XLT 4WD, 4.0L OHV V6
Would the factory 15" wheels (10-hole 10-slot style, if it makes a difference) from 2000 fit onto a 2012 Ford Escape (specifically 4-cyl 2WD) without the need for brake modifications or spacers?
The 2012 Escapes came with 16" or 17" wheels and a slightly different offset, but the same bolt pattern and overall diameter within 1%. However, the front disc brakes are (surprisingly) a bit larger diameter, so I'm not sure if the calipers would then be too large to accommodate 15" wheels.
