Wilmoth
- August 9, 2021
- Cookeville, Tennessee
- 2000 Ford Explorer XLT
Thanks for welcoming me to the group! This site has been very helpful to me over the years! I currently have a few questions I need some answers for.. First off I’m needing torque specifications on everything I’m listing below and any tips to go along with it will be greatly appreciated! Thanks in advance as well.
1. Replacing drivers side axle, AWD/4x4..
2. Replacing front shocks..
3. Replacing sway bar and rubber mounts..
4. Replacing sway bar links..
Also there is adjustments located on both sides of the frame and I’m not sure how they are supposed to be set.. I seen a thread saying to use a ruler to make sure everything is level from the ground.. What is the purpose of these adjustment bolts located through the frame as well? Once again, any help is appreciated and thank you in advance!
Sincerely, Wilmoth.
Sincerely, Wilmoth.
